DQMH Consortium Toolkits Discussions
Message Pumps in DQMH
On a first - quick - glance, I can't see anything wrong with your block diagram. Maybe the problem lies outside your captured part? Which events are you triggering, what does the helper loop do, ...?
If you want, we can do a quick TeamViewer (or similar) session tomorrow in the morning.
DSH Pragmatic Software Development Workshops (Fab, Steve, Brian and me)
Release Automation Tools for LabVIEW (CI/CD integration with LabVIEW)
HSE Discord Server (Discuss our free and commercial tools and services)
DQMH® (Developer Experience that makes you smile )
Message 31 of 41
(4,213 Views)
Your problem is that you are sharing a single Event Registration between two parallel event structures.   Events are not designed for this and have this odd behavior.  Crete a separate Event Registration for your helper loop.
Message 32 of 41
(4,209 Views)
Of course, James. That escaped my tired eyes 😞
Message 33 of 41
(4,205 Views)
For a detailed explanation of why we should not fork the Event Registration wire, check out this post:
https://forums.ni.com/t5/Delacor-Toolkits-Discussions/Registering-to-broadcast-events-from-many-modu...
The general rule should be a Register for Events Node for each Event structure (with dynamic event terminals visible) handling events.
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
Message 34 of 41
(4,197 Views)
Thanks @ all. Problem solved.
That way it works great.That way it works great.
Message 35 of 41
(4,186 Views)
Any mention of randomly missing events should immediately make one think of a shared event registration.  I still remember debugging this in one of my applications 10 years ago.
Message 36 of 41
(4,181 Views)
Makes me realize that I do mention a second event registration node in my article, but I do not explicitely state the importance. I'll edit the text accordingly. Thanks again for pointing that out, James.
Edit: Update done.
Message 37 of 41
(4,176 Views)
@joerg.hampel wrote:
 ...in my article,...
Can't post an image in a reply to the article, so a suggestion here.   Remove these wires, as you don't need them and they reduce readability of what you are doing.
Message 38 of 41
(4,169 Views)
That's interesting James, I knew you didn't need the input wire (unwired = unchanged) but I didn't know that you don't need to wire the output of the register for events node... I always thought you had to "update" the event structure after changing the registration...
Nice to know!
Message 39 of 41
(4,164 Views)
I'm always having a hard time with these "seems to work without" things, as it's hard to find official documentation or comments about these things...
Agreed, the LabVIEW help states "Registered events stay registered until you explicitly unregister them [..]", so wiring an event source that doesn't change is unneeded.
With the Event Registration Refnum going from the Register For Events node's output to the Dynamic Event Terminal on the right side of the event structure, I'm not really sure if I agree that deleting this wire makes the code more readable - but that might just be me having to get used to it.
Anyway, thanks James for taking the time to look at the article and point those things out!
PS: Edited for clarification
Message 40 of 41
(4,160 Views)
