DQMH Consortium Toolkits Discussions
Multiple Module Starts/Stops
Is there a built in mechnism to track the sources of module starts?
I have the situation where I start a module from multiple locaitons (say from TestStand sub sequences) but I don't want the module to stop untill all the sources send a stop.
(4,382 Views)
Hi Paul,
Out of the box there is not such a functionality.
If you need to have a master owner of the module, then I would suggest you stop the module only in a single location within that Master owner after it has send a request to stop all the other modules with the input set to "wait for module to stop" set to true. Then call this module's stop.
I hope this helps.
Fab
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
(4,182 Views)
