DQMH Consortium Toolkits Discussions
Panther Dashboard Error 7 when creating a new module
Whenever I create a new Module or Event I get the error below. The modules seem to work as they should, but I figure I should find out why this is happening. I'm on Windows 11, LV 2025 64-bit Q3, the latest DQMH. The modules I've created so far pass the validation test.
David Ferster
Lafayette Instruments
Error 7 occurred at Open VI Reference in Panther Dasboard Scripting Hooks.lvlib:_Refresh Module By Name.vi->PDash - Remove DQMH Event.vi->DQMH Remove Event.lvlib:Remove Event - Call Post Scripting Actions.vi->DQMH Remove Event.lvlib:Remove Event.vi->DQMH Remove Do Something.lvlib:Remove Do Something.vi->DQMH New Module.lvlib:Script New Module.vi->DQMH New Module.lvlib:Add New DQMH Module.vi
Possible reason(s):
LabVIEW: (Hex 0x7) File not found. The file might be in a different location or deleted. Use the command prompt or the file explorer to verify that the path is correct.
Nonexistent GPIB interface.
VI Path: C:\Program Files\National Instruments\LabVIEW 2025\vi.lib\PantherLAB\Panther Dashboard\Panther Dashboard\Refresh Module By Name.vi
Message 1 of 9
(246 Views)
Thanks for bringing this to our attention but this seems to be Panther Dashboard error, not a DQMH error. I will let Enrique from PantherLabs know
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
Message 2 of 9
(186 Views)
Hi David, Panther Dashboard works the following way:
  1. When you click the button to create a module or right-click the project and select Create module, Panther Dashboard calls the DQMH Scripting tools (DQMH Framework)
  2. The DQMH Scripting tools have their own workflow, which handles a variety of tasks. At the end of each DQMH Scripting Tool execution, the DQMH Framework executes the Scripting Plugins located under [LabVIEW Data]\DQMH Scripting Plugins\  see this document  Scripting Plugins
  3. When Panther Dashboard is installed, it places a series of scripting plugins under the LabVIEW Data folder to close the loop after each User Selection. These scripting plugins communicate with the Panther Dashboard to refresh the Tree, add modules to it, add events, rename module/events, etc.
What I can imagine is happening here is that you moved/deleted some of the files under [LabVIEW Data]\DQMH Scripting Plugins\, so please could you please uninstall/install Panther Dashboard and see if the problem is gone?
If the problem persists, please create an issue here: https://github.com/PantherLAB/PantherDashboard/issues
Enrique.
Message 3 of 9
(163 Views)
Dear Enrique,
I'm sure I never moved any files related to DQMH. I never installed Panther Dashboard, and am not using it. The error appears when I am creating events or modules directly from the DQMH items in the Tools menu.
David
Message 4 of 9
(158 Views)
Well, your post title made me think you were talking about Panther Dashboard. I can't think a way that you ended up running Panther Dashboard code without installing it, that is a separate tool from DQMH.
Message 5 of 9
(145 Views)
I wonder if files were copied from the [LabVIEW Data] folder from one machine onto another machine. Or maybe both machines share a OneDrive location for the [LabVIEW Data] folder? Maybe Machine A had Panther Dashboard installed, but Machine B does not. Machine A's [LabVIEW Data] folder could have been copied over to (or being accessed by) Machine B, and the folder includes the Panther Dashboard post-scripting plugin VIs. Machine B runs DQMH scripting tools... but if Panther Dashboard isn't installed on Machine B, then those scripting VIs in the [LabVIEW Data] folder are going to have missing dependencies, resulting in the DQMH scripting errors.
That's my best guess as to what's going on here.
Message 6 of 9
(140 Views)
Hi David,
You were at the DQMH Day, and I did include Panther Dashboard in the vipc file we used for the training.
Would you please open your VIPM and filter only to show what is installed? Let's verify which version of DQMH you have installed and confirm that Panther Dashboard is not installed.
Fab
Message 7 of 9
(119 Views)
Panther Dashboard was not installed according to VIPM. I think at the class I used a different VM. In any case, I have now installed it and the errors no longer appear.
Thanks for your help.
David
Message 8 of 9
(108 Views)
If this issue reoccurs, the upcoming Panther Dashboard release will enhance error handling for Scripting Plugins. If the tool isn’t installed but the scripting plugins are listed under LabVIEW Data, an error will prompt you to install Panther Dashboard or reinstall it.
Once the tool is installed, the scripting plugins are moved to LabVIEW data, thanks to VIPM’s post-install custom actions. When the tool is uninstalled, another post-uninstall custom action will handle the deletion of Panther Dashboard Plugins.
This tool utilizes separate VIs; the majority of them are located under vi.lib, but the scripting plugins need to be under LabVIEW Data. This setup isn’t standard. However, it’s necessary because that’s how the framework is designed.
Putting this comment here in case someone else falls into the same issue.
Enrique.
Message 9 of 9
(8 Views)
