DQMH Consortium Toolkits Discussions
RAM usage increase while using DQMH on RT target
@ChrisFarmerWIS wrote:
You can use Open Variable Connection.vi to open the variable once upon startup:
I guess the question is why you use the explicit VIs like this rather than just placing a shared variable on the block diagram?
I used the VIs because I needed the flexibility to address the IOs by name. Now replaced them with shared variables - didn't make any difference.
Message 11 of 11
(335 Views)
