DQMH Consortium Toolkits Discussions
Read version number of the DQMH VI package programmatically?
I think the subject says it all:
Is there a way to determine the version number of a VI package (here: the Delacor QMH) - as it would appear in VI Package Manager - programmatically from my LabVIEW application?
So we're using 3.1.0.18 at the moment, and I would like that to show up in different places (GUI, readme, ...).
DSH Pragmatic Software Development Workshops (Fab, Steve, Brian and me)
Release Automation Tools for LabVIEW (CI/CD integration with LabVIEW)
HSE Discord Server (Discuss our free and commercial tools and services)
DQMH® (Developer Experience that makes you smile )
Message 1 of 8
(4,993 Views)
Accepted by topic author joerg.hampel
Hi Joerg,
All of the DQMH VIs get the following text at the end of their VI Description:
"Based on Delacor QMH Project Template" followed by the DQMH version.
You could get the version information by using the VI Description property node and then some regular expression code.
I created the following quick and dirty code and put it in the DQMH Module.lvlib:Module Name--constant.vi just as an example:
Save the image above on your code and you should be able to drag the snippet into any DQMH generated VI and have it report the version.
This would of course only give you the version used to create the package not the current version currently installed.
Fab
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
Message 2 of 8
(4,958 Views)
We already do that very same thing with some of our own library VIs. Perfect, that's all I need.
Thanks, Fab!
Message 3 of 8
(4,955 Views)
Old question, I know. But I have a variation, how can I programmatically determine what version of DQMH is installed? Do I have to query the VIPM API somehow or is there another way?
Sam Taggart
CLA, CPI, CTD, LabVIEW Champion
Read about my thoughts on Software Development at sasworkshops.com/blog
GCentral
Message 4 of 8
(3,256 Views)
VIPM keeps copies of installed packages in folders (named by LabVIEW version) somewhere under the Program Data folder.  If you have a look you will find it.
I've used this in a pre-build vi that records all installed packages in the EXE's build log.
Message 5 of 8
(3,248 Views)
I figured out how to pull it out of the VIPM API - although that requires a license.
Digging through the files might be more widely applicable.
Sam Taggart
GCentral
Message 6 of 8
(3,240 Views)
And might be more performant as well.
Sam Taggart
GCentral
Message 7 of 8
(3,238 Views)
For DQMH, I posted a related feature request long ago:  https://forums.ni.com/t5/Delacor-Toolkits-Documents/DQMH-Feature-Requests/tac-p/3808494/highlight/tr...
Message 8 of 8
(3,229 Views)
