DQMH Consortium Toolkits Discussions
Should API testers exit on error?
I'm wondering if the API testers should exit on error instead of displaying but then ignoring the errors coming from the module? Sure, there are cases when we really need to shut down the tester (and most likely the module as well) but generally speaking I dont see why an error coming from the module should stop the API tester itself.
Thx.
(1,611 Views)
The DQMH Consortium agrees with you, and is planning on removing the error stop behavior from API Tester VIs in a future DQMH release.
(1,585 Views)
