DQMH Consortium Toolkits Discussions
Stop module.vi for cloneable running as singleton - wait for module to stop
Hiya,
What's the basis for always waiting for a module to stop in the stop module vi when running a cloneable module as a singleton? It's documented in the vi description that that is the expected behaviour, but I was wondering why. Also, is it ever safe to wire an "AND" to the boolean selector into the case structure "DQMH_POLL_RUNNING_AS_SINGLETON" so that it only sees true IF running as a singleton AND wait for module to stop =True?
I had previously (and perhaps foolishly seeing as how I now see its in the vi description) added that AND functionality to prevent the VI waiting for stop when calling the stop module.vi from within a module which is running as a singleton despite being cloneable... that was because I was seeing that vi essentially timing out in that case and therefore taking longer than expected to stop... (I dont actually do that any more as I found a much cleaner way of exiting from within the module).
So now, I was just wondering what the reasons for that decision were and if it can be omitted safely as I did, or whether i need to go and chase down the modules I did that in and change the behaviour back and refactor to get what I need.
For info, I almost always make my modules cloneable but in some cases will change the "run as singleton" input to the start module a true constant to force them to run as singletons as for now I only want that behaviour, but am concerned that in the future I might want to make it cloneable after all...
Thanks!
Paul
(763 Views)
The internal module state for a cloneable running as singleton is different than the state when running as cloneable. If you try to start a cloneable (running as cloneable) while a cloneable running as singleton is shutting down, things "won't work". So we force a complete shutdown of a cloneable running as singleton before letting you fire things up again.
(736 Views)
Ok, so bad idea to add the and logic. Got it.
You mention specifically the case of having a cloneable being launched as a cloneable whilst an instance of that same cloneable running as a Singleton is shut down as an issue, what about the case where it's always being called as a Singleton? (I.e. I've hard coded a true constant inside the start module vi). Could that cause issues?
Generally I think the modules I have created as clone able but running as Singleton are fairly long lived and not stopped started, but worth a check now for sure.
Thanks for the quick reply.
(723 Views)
