DQMH Consortium Toolkits Discussions
Strange Profil with DQMH Module
Hi All
I have tested my program with the profile tool and I have a strange call with my module. This module is based on a DQMH clone module (6.0) where I start only one instance. If you take look at the screenshot, you can see a lot of instance in instance in intance... I'm not sure this is normal but I want your opinion about that. Perhaps It's an effect of asynchronous call used to load module instance.
(1,319 Views)
Those are instance VIs called by your Main VI. I'm guessing you have one or more Express VIs or Malleable VIs (.vim) being called in your main VI, and each of these will generate an instance VI in the profile list.
(1,315 Views)
Hello Darren
This message is out of the box but we have a serious problem here and time runs out. And maybe you have the solution in your brain, because you work at NI and if not I'm sure you know someone in the company who can solve this general issue. So please follow the link I place here to your forum and read it and give us a comment!
https://forums.ni.com/t5/Multifunction-DAQ/DAQmx-with-Excel-64-bit-VBA/m-p/4185611/highlight/false#M...
Very best regards.
GoAr
(1,259 Views)
