DQMH Consortium Toolkits Discussions
Trouble with DQMH module using OPC UA in a packed library
Accepted by topic author Brett_Percy
Just a quick update on the compiled code setting, I've turned Remove compiled code back on, cleared out the object cache, rebuilt the library and cleared out the cache again
The library still loads in LabVIEW and in TestStand and appears to be working fine.  So it looks like the typedef disconnection was the key issue
Cheers
Brett
Senior Software Development Engineer
Certified LabVIEW Architect and LabVIEW Champion
https://theLonelyAnt.com
https://GDevConANZ.org.au
Message 11 of 11
(1,146 Views)
