DQMH Consortium Toolkits Discussions
Unable to create Modules without "Do Something" events
Dear DQMH Developer Team,
We are currently trying to create a DQMH Project without the "Do Something" events. The steps we perform are:
1) Create Project from template containing a Singleton and a Cloneable module, both without the "Do Something" event
     -> The project is created and everything looks good.
2) Add a Singleton module without the "Do Something" event using Tools -> Delacor -> DQMH -> Add new DQMH Module...
     -> The Module is created, however both the Main.vi in the library and the Test [..] API.vi need four VIs, which are not contained in the Project (picture attached). These are not created, since we chose not to create the "Do Something" event.
What are we doing wrong? We are using the following configuration:
Windows 7 Ultimate 64-bit
LabVIEW 2016, 32-bit
Delacor QMH Project Template 3.1.0.34
Any help is greatly appreciated,
Jascha Eisenberg
(3,857 Views)
We were able to reproduce the issue you are experiencing. We will investigate further and give you a solution.
In the meantime, the workaround is to create your Singleton DQMH module on a blank project and then add it to the project where you wanted to use it.
We apologize for the inconvenience and thanks for letting us know.
Fab
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
(3,829 Views)
This issue has been solved in DQMH 4.0. You can download the Beta version here
http://delacor.com/announcing-dqmh-4-0-beta/
(3,437 Views)
