DQMH Consortium Toolkits Discussions
Useful right-click plugin for DQMH development
Last week I posted a new plugin to the LV Shortcut Plugins community:
Set Current Event to Value Change
To summarize, this plugin lets you right-click a control terminal inside an event structure, and it will configure the current event frame for the 'Value Change' event for that control. I think this plugin will help you save time when updating your DQMH Tester VI after creating a new request event...since the new request event VI is placed in an event frame in the tester for you, you can quickly create a control (many times from a terminal of the event VI itself), then use this right-click option to configure the Value Change event.
See the plugin page for more details. The plugin is available for use in LabVIEW 2016 and later.
(4,093 Views)
Thanks for sharing, I will give it a try.
This will work great with some of the new features DQMH 3.0 will have for LabVIEW 2016
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
(3,873 Views)
