DQMH Consortium Toolkits Discussions
Validation of newly created Cloneable Panel module has lots of failures in 6.0
I installed DQMH 6.0 and then created a new project from the CML DQMH template.  I ran the validation on the entire project: all of the Stop Modules needed to be updated - not a big deal.  Then I added a new Cloneable Panel module to the project.  This resulted in an error on creating the Tester.  I pressed the continue button and the module was created without further issue.
Then I ran the validation on the new cloneable panel module (only that module).  The result is a list of ~16 lines of items that need to be fixed.
Again, this is freshly created project and freshly created module that was built from a fresh DQMH 6.0 install.  Do I have an issue with my installation or is this an issue that others are able to repeat? 
I have not attempted to fix any of the failures at this point.  I will check here on Monday prior to running the Fix command on any failure lines.
(2,426 Views)
I didn't get any error messages while creating the module, but the validator finds the same issues your screenshot shows.
DSH Pragmatic Software Development Workshops (Fab, Steve, Brian and me)
Release Automation Tools for LabVIEW (CI/CD integration with LabVIEW)
HSE Discord Server (Discuss our free and commercial tools and services)
DQMH® (Developer Experience that makes you smile )
(2,409 Views)
Maybe DQMH is getting confused because you've titled your new module "Cloneable Panel", which is the same as the template.
Try calling it something else perhaps?
Christopher Farmer
Certified LabVIEW Architect and LabVIEW Champion
DQMH Trusted Advisor
https://wiredinsoftware.com.au
(2,400 Views)
Accepted by joerg.hampel
You're creating a new module from a template called "Cloneable Panel", and you're naming the new module "Cloneable Panel". I'm guessing that the error 7 is stemming from the fact that the new module you're creating has the same name as the template it's being created from. Try creating the new module with a different name.
Also, 'Cloneable Panel' is not a module template that ships with DQMH. That is likely a template that you created or downloaded/installed from somewhere, and it was created with an older DQMH version, which is why it's returning validation failures.
(2,392 Views)
Oops, I hit the „accept as solution“ button by accident.
The „Cloneable Panel“ template ships with MGI‘s Panel Manager for DQMH. Like Darren says, it is not part of the DQMH package but a 3rd party add-on.
(2,368 Views)
Thank Christopher, Darren, Joerg for quick and accurate responses.  I think you're all correct.
I deleted that module and created a new cloneable panel module with a different name and didn't get the error.  All of the validation failures are still there, so similar to what Christopher reported.  I guess I will fix them for now and wait for MGI to update their panel manager to 6.0.
Thanks again!
Scott
(2,338 Views)
