DQMH Consortium Toolkits Discussions
sb RIO 9636 instead of myRIO
Hey guys,
thank you for your LIA-project. But I have a problem. Could you compile your code on a sb RIO and send me the bit-file? I can't compile the code on my sb RIO as the bitfile was compiled on a myRIO. I would prefer a VI to compile on the sb RIO. Do you have a VI with the code you're using on the FPGA?
As I am using LV2012 it would be perfect to send the VI on LV12 version.
Kind regards and thx for your work.
Slev1n
(5,065 Views)
Hi Slev1n,
Thanks for your interest in the myRIO Lock-in Amplifier toolkit.  Unfortunately we are only supporting this toolkit for use in myRIO at this time.
Best Regards,
MM
(4,502 Views)
Hey MM,
thanks for your answer. I do now own a myRIO and I will be going to try the code on it.
But would it be possible to look into the code which is compiled on the FPGA via the bitfile? I mean could you give me the VI behind the bitfile because if I will use this tool for my master thesis I'd like to understand how to realize such things on a FPGA.
Kind Regards
Slev1n
(4,502 Views)
Hi Slev1n,
We do not make the FPGA code available.  However, the documentation goes into some details of the implementation.  You can also search Google and NI community for 'FPGA lock in amplifier', and you will find several examples written for LVFPGA.
MM
(4,502 Views)
