DQMH Consortium Toolkits Discussions
start a clonable DQMH as a singleton on a real-time target ?
Hi
I am in the testing phase of my project and I encountered many synchronization and debugging errors in a clone module for XNET communication on a real-time CRIO target.
so my question, is it possible to run multiple instances as singletone? i know the option exists for windows testers? can I do the same on a CRIO?
(1,779 Views)
Hello Hichem,
you can definitely run your cloneable module as a singleton, but if your goal is to debug it on your RT target it will not help because the option is only made to ensure only one instance of the module is running at a given time. The main.vi is still reentrant so you can't probe it.
My advice in this situation is:
  • use the status did change broadcast and use the tester
  • change module subvi to non-reentrant execution during your debugging steps
  • Add file logging
Debugging RT applications is still challenging 😉
Note 1: that there is also a feature request related to debugging DQMH  modules on RT here --> https://forums.ni.com/t5/DQMH-Consortium-Toolkits-Feature/Simple-Tools-for-helping-RT-debugging-DQMH...
Note 2: If your issues come from synchronization between multiple instances making your module a singleton is not going to help a lot...
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
(1,774 Views)
