Dallas User Group Community
Three Levels of Data Logging Software from National Instruments
One of the most common data acquisition (DAQ) applications is logging acquired  data to disk for analysis. Data logging software can be classified into one of  three categories: turnkey, configurable or programmable. Regardless of your  application need and preference, National Instruments’ data logging software  offers the ideal user experience while always providing the path to expand your  application with NI LabVIEW, the powerful graphical programming environment  ideal for the most complex data logging applications.
Turnkey data  logging software requires very little user interaction and allow you to log data  to disk in seconds.  Configurable solutions expand on this functionality to  allow the user to configure multiple aspects of their data logging application,  including alarms, triggers and analysis without programming. Programmable data  logging software is the most powerful and gives you the widest scope of  functionality. The data logging solution that is best for you depends on your  system requirements and application needs. Since National Instruments DAQ  hardware is compatible with multiple types of data logging software, you can  pick the hardware and software that is right for you. This article introduces  the three levels of data logging software for use with National Instruments DAQ  hardware.
Read the full article here: http://zone.ni.com/devzone/cda/tut/p/id/3677
Message 1 of 1
(3,859 Views)
