The vi "DAQmx Tristate Output Terminal (VI)" lacks an input to toggle the drive state of the output.
Current version can only tristate - not enable the output. It is rare that you don't need both options.
Tri-state DAQmx
Without the enable option, it is a superfluous VI which only does half the job.
A workaround is straightforward using the technique here https://forums.ni.com/t5/Example-Programs/DAQmx-Digital-I-O-Toggling-Tristate-on-Individual-Lines-in...
