 Mister_Rose
			 on
		11-01-2010
		12:56 PM
			Comment
			Mister_Rose
			 on
		11-01-2010
		12:56 PM
			Comment
		In MAX, you can open up a test panel for a DAQmx device.
I woudl like to format the numbers on the axis of the graphs. I have a calibration routine that requires that the signal get as close to 5 V as possible. When you get to less than 10mV, you the numbers on the vertical axis go from 5.01 to 5. So all you see on the graph is a bunch of 5's. It would be nice to be able to see the values in as much resolution as the channel will handle. Even at the maximum range, it can still do 2mV per bit. It would be nice to see 5.004 instead of 5.
