Data Acquisition Idea Exchange
JÞB
Change DAQmx Generate Code >> Configuration output vi
Status: New
When I drop a DAQmx Task constant on my LabVIEW block diagram, I have the right-click menu option to Generate Code >>Configuration
This scripts out a sub.vi that creates the Task by adding each channel with channel specific properties sequentially, one channel at a time, to repeated calls of DAQmx Configure Channel.vi.
I have a hard time saving that vi output!  I have not really learned how to name it properly without Using:  "BLEEP_BLEEP_BLEEP_Configuration_that_cannot_be BLEEPING_scaled.vi"
I believe that an autoindexing loop would be much nicer.
My grandmother thanks you for improving my manner of speach.
1 Comment
Active Participant
There are two templates for DAQmx code generation of the Configuration. One of them produces the output you described:
The other is a high-channel count template that gets invoked for tasks with 8 channels or more and looks like what you described you wanted:
The high-channel count template channel configuration section is automatically generated to scale even when you have multiple measurement types:
Most of us would like the scalable option to kick in when channels is 3 or more. It would be nice if developers could decide what their threshold is.
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
