Denver - ALARM
LabVIEW Job Openings in Colorado
This thread is intended as a repository for job postings for the Colorado area.  Previously, job postings were often done through Announcements, but recently the forums have been changed so that Announcements can only be created by Administrators.  Please post any LabVIEW job openings to the Discussions instead.  Rather than creating individual postings for every job opening, feel free to reply to this discussion with new job postings.
DaveT
David Thomson Original Code Consulting
www.originalcode.com
National Instruments Alliance Program Member
Certified LabVIEW Architect
Certified Embedded Systems Developer
There are 10 kinds of people: those who understand binary, and those who don't.
Message 1 of 30
(29,911 Views)
Great LabVIEW Job in Boulder, CO
Boulder Professional & Technical Services is currently interested in several Information Technology Professionals as a part of our team of consultants for our client.
Please review the job description below and submit a resume and cover letter identifying the job and the respective skills you have that match our requirements.  This is a very important step to include in your response and it will get you a timely response.  E-Mail george@bpts.net or fax your resume with references and salary requirements to (303) 530-4855.
Sr. Embedded Software Engineer - Boulder
Job Type:                    Contract (Successful candidates are employees of BPTS)
Length of Contract:   1 year with opportunity for more
Pay:                             $55-$65/hr ($114,400 - $135,200/year)
Submittal Deadline:  Open - until position is filled
Start Date:                  Immediate
U.S. CITIZENSHIP OR PERMANENT RESIDENCY IS REQUIRED
PRIMARY RESPONSIBILITIES:
The Senior Embedded Software Engineer will have primary responsibility to design, develop, test and integrate test system software and hardware for a variety of applications including subsystem command and data handling, low level hardware control, automation, custom interfaces, and communication software for ground, airborne and/or space systems.
The technical work environment is dynamic and requires a person who is comfortable operating at a fast pace, is detail oriented, and who drives for results, execution and excellence.
WHAT YOU'LL DO:
  • Perform requirements, analysis and decomposition, support system level architecture definition and software design.
  • Implement and certify test systems in the labs using commercial test equipment
  • Applications are programmed in LabVIEW. Formal software development methodologies apply.
WHAT YOU'LL NEED:
  • Experience with LabVIEW and other NI technologies: TestStand, LabVIEW Real-Time, LabVIEW FPGA and Device Drivers.
  • Experience with the following interfaces: GPIB, Serial, VXI, custom DIO, Ethernet, VISA, IVI, PXI.
  • Motion system and Vision system experience is desirable.
  • Ability to apply sound software engineering principles to the development of software through the full lifecycle
  • Experience working and/or leading efforts that require software requirements definition and analysis, architecture definition, design, implementation and test
  • Ability to operate at the system level and interface to all engineering disciplines
  • Ability to grasp new technical concepts including hardware/software interactions, real-time processing, and concepts of operations
  • Self -starter, references that confirm good interpersonal and communication skills, ability to work independently and on a team
  • Working knowledge of configuration management principles
  • Working knowledge of software quality principle.
An active or previous clearance is desirable.
Applicant selected may be subject to a government security investigation and must meet eligibility requirements for access to classified information.
  • BS in Engineering or a related technical field is strongly preferred plus 8 or more years related experience.
  • In addition to the typical educational and experience requirements, a demonstrated capability to adequately perform the essential functions and responsibilities of the position and exhibit the skills and competencies of the grade level should be considered. Each higher level degree, i.e. Ph.D. may substitute for two years of experience.
This job opportunity is to support a long-term contract and requires little or no travel.   It does require availability during core business hours for an average of 40 hours per week.  The salary earning levels are competitive with paid time-off, 401(k) Plan and employees may self-fund cafeteria benefits.  Preference is given to qualified individuals having references that can substantiate your excellent communications and interpersonal skills.  College graduates with leadership and technical backgrounds are desired.  Minorities and women are encouraged to apply.
E-Mail to george@bpts.net or fax your resume with references and salary requirements to: (303) 530-4855.
Boulder Professional & Technical Services, LLC
EOE M/F/D
Message 2 of 30
(9,334 Views)
Bob King tells us that there are several positions open at the CSM Engineering Division:
There are positions for
1.  lecturer in mechanical engineering,
2.  lecturer in electrical engineering, and
3.  Adjunct faculty.
The positions are listed and described at: http://inside.mines.edu/HR-Academic-Faculty
Message 3 of 30
(9,334 Views)
We have an opening posted at Droplet Measurement Technologies for a EE.  We use a lot of LabVIEW at DMT, so getting someone with good LV background would definitely be a plus.  Here's the full posting:
Electrical Development Engineer
Job Responsibilities:
Droplet Measurement Technologies is seeking an electrical engineer to support the design and development of scientific measurement instrumentation.  Responsibilities include design, prototype, and testing of analog and digital electronic circuits, including embedded microprocessors/microcontrollers and FPGAs.  Development within a team environment will be from initial concepts through hardware/software integration, testing, and documentation.
Required:
  • BS degree in Electrical Engineering, or equivalent experience
  • Minimum 3+ years experience in developing embedded systems
  • Digital and analog design expertise
  • Ability to write C language code
  • Experience with PCB layout
  • Experience with Verilog and/or VHDL for firmware development
  • Strong written and oral communication skills
  • Excellent interpersonal skills, high integrity, team player
  • Ability to handle multiple tasks and priorities simultaneously
  • Attention to detail with good organizational skills
  • Proactive, self-starter, excellent follow through
Desired:
  • MS or significant graduate-level course work in above disciplines
  • Experience with computer-controlled sensors/instrumentation, and computer-based data acquisition systems
  • Data analysis skills
  • Experience with PADS PCB for board layout;  SolidWorks for MCAD;  LabView for instrument control programming;  and/or Xilinx tools for FPGA development
  • Experience configuring Linux kernels for embedded platforms
  • Experience designing in an ISO9001 manufacturing environment
  • Design experience in meeting FDA laser safety, FAA, and CE regulations
Droplet Measurement Technologies, a private company located in Boulder, Colorado, has been serving the atmospheric sciences community since 1987 with high-precision electro-optical instrumentation to measure aerosols and droplets in airborne and ground-based applications.  Learn more about our company at www.dropletmeasurement.com.  DMT is an equal-opportunity employer.
Please send your resume to Pat Keady, Director of Engineering, at jobs2@dropletmeasurement.com.
Message 4 of 30
(9,334 Views)
Display Systems Engineer - LON25360
Description
The FLCOS Microdisplay Division at Micron is seeking to fill a position for a display systems engineer. As a Systems Engineer at Micron, you will be part of a highly collaborative team responsible for developing, prototyping, measuring and validating future technologies for microdisplay products.
Your responsibilities will be equally split between software development and electronic design. The software component requires strong LabVIEW programming skills to automate test equipment for the characterization of display panel and engine products. The electronic design component covers all phases of hardware development of microcontroller based systems from definition to deployment. Familiarity with Microchip PIC architecture and Xilinx FPGA development is a plus.
Qualifications
Successful candidates for this position will have:
  • 5+     years experience coding with LabVIEW.
  • 3+     years experience with NI-DAQ hardware.
  • Solid     experience with object oriented programming (LabVIEW , C#, C++, Java,     VB.Net).
  • 3+     years of experience with schematic capture and electronic design.     Preference given to Orcad schematic capture and Cadence design tools.
  • Experience     with SQL/MySQL.
  • Exceptional     debug skills and expertise with lab equipment including oscilloscopes,     logic analyzers, and protocol specific instruments.
  • Ability     to work with outside contractors and vendors.
  • Ability     to work on multiple development tasks simultaneously.
  • Self     motivated with the initiative to work independently.
  • Excellent     problem solving skills.
  • Excellent     communication and interpersonal skills.
  • Experience     with FPGA development, preferably with Verilog and Xilinx tool suites.
  • Experience     with microcontroller system design and programming. (Preferred)
  • C     and/or C++ and assembly language programming skills. (Preferred)
  • Experience     with SVN version control. (Preferred)
  • Understanding     of liquid crystal display and video principles. (Preferred)
Education: Bachelor's degree in ElectricalEngineering or Computer Engineering.
Please apply online at https://micron.taleo.net/careersection/10000/jobsearch.ftl?lang=en.  Job Number: LON25360.
Message 5 of 30
(9,334 Views)
I have two customers who are looking for engineers in the CO Springs area.  One is in the Mil/Aero industry and is looking for a software engineer, potentially with experience in LabVIEW and TestStand.  The second is in the pollution control industry and is looking for someone with LabVIEW experience and experience in the industrial/process control world.
Please let me know if you're interested, and I will pass your resume and contact information along.  Thanks!
Eric Cunningham
Field Engineer
eric.cunningham@ni.com
Eric C.
Message 6 of 30
(9,334 Views)
I would be more than happy to talk with them. Is it contract or full time?
Either works.
Tom Houston
Message 7 of 30
(9,334 Views)
Both are full time.  Can you send me your resume at my email address: eric.cunningham@ni.com?
Eric C.
Message 8 of 30
(9,334 Views)
Message 9 of 30
(9,333 Views)
Can you give me any info on who is looking?
Message 10 of 30
(9,333 Views)
