Developer Center Discussions
Custom categories in LabVIEW options dialog
It would be very usefull if we could integrate a custom option in the standard LabVIEW options dialog.
Looking at the  %LabVIEW%\resource\dialog\PreferencesDialog\PreferencePages folder I see  a pageTemplate.vit template.
I have created a new VI (prefPage_CCT.vi) and was hoping that a section  would show up in the options dialog.
Unfortunatly this doesn't work.
Adding this would make our add-ons integrate better with the LabVIEW IDE.
Some further reading (with a hack) on LAVA.
Ton
My LabVIEW Ideas
Message 1 of 13
(17,073 Views)
Hello Ton,
Excellent idea! We're following up with R&D to get their opinion on the matter and I'll deliver an update to you ASAP.
Kind regards,
-Bob
Message 2 of 13
(10,954 Views)
BOB wrote:
Hello Ton,
Kind regards,
-Bob
Ow, just an update, and I was hoping for a solution...
Thanks Bob,
Ton
My LabVIEW Ideas
Message 3 of 13
(10,954 Views)
I've not forgotten; I've just not received a response from the developer yet. I'll get back to you when I have something!
-Bob
Message 4 of 13
(10,954 Views)
Bob, any chance of opening up the source of this?
I am keen to re-use the framework in my own apps, not to add anything to LV preferences.
Message 5 of 13
(10,954 Views)
nrp, you might want to check out xCE.
David Staab, CLA
Staff Systems Engineer
Message 6 of 13
(10,954 Views)
I've sent another email to a developer requesting more information regarding the framework, but even if we expose a method for plugging into the framework it is unlikely R&D would agree to opening the source code...David has a great recommendation of using the xCE or Generic Configuration Editor Reference Example, what are your thoughts on this nrp?
-Bob
Message 7 of 13
(10,954 Views)
Thanks David,
I remember taking a look at this framework sometime ago, but had totally forgotten about it. I will have to spend some time digesting it again 🙂
Message 8 of 13
(10,954 Views)
nrp,
Check out the following document. We have provided an interface to develop your own options dialog using the same framework. The main VI is still password protected for now, but you can create your own options pages and call them in the framework.
https://forums.ni.com/t5/Reference-Design-Content/LabVIEW-Options-Dialog-Framework-ODF/ta-p/3526554
This does not allow you to add custom pages to the existing LabVIEW options dialog for LV Add-Ons however.
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
Message 9 of 13
(10,954 Views)
Hello Ton,
It will require LabVIEW R&D developer time (code changes) to allow third-parties to plug into the existing LabVIEW Options dialog.  We, the Partner Program Engineers, will work with R&D to pursue this in a future release -- I cannot make any promise as to when, unfortunately, but I assure you we will work on this!
Kind regards,
-Bob
Message 10 of 13
(10,954 Views)
