Developer Center Discussions
Software binding activation problem
Hello
I am triying to license a toolkit usingTPLA. It works fine when I use hardware binding (in LFEdit) combined with the trigger code 28 in the Solo server (using EZ Trigger). If I try to use software binding I cannot activate the toolkit. I get the activation succeded message, the number of left activations on Solo Server decreases, but the toolkint does not activate (I tried with trigger code 28, 18)
Can anybody give me a hint ?
Cristian
(9,242 Views)
Hello Cristian,
It's very likely a permissions issue.  Software binding requires LabVIEW to write to certain registry locations and protected areas on disk.  Doing so requires administrative rights on the computer.  Typically your installer should call RegisterAddon.exe during installation which will request administrative access and then initialize these registry locations.  If you did not call RegisterAddon during the install process, you can either do so after the fact, or simply run LabVIEW with administrative rights before you activate the toolkit.
The above only is a problem on OSes that have UAC enabled (Windows Vista, 7, 8).  For Windows XP computers there is a semi-common problem which is a result of out of date certificates.  This can be resolved by updating your computer with the latest Windows Updates which installs the correct certificates.
Hope this helps,
David
(7,134 Views)
Were you using VIPM for the install process?
(7,134 Views)
Hello David
Thank you for the answer. It works perfectly now. Actually I had a vi that was supposed to launch RegisterAddon.exe, but there was a mistake the way I was calling the System Exec.vi.
It looks like if you pass something like "cmd /c RegisterAddon.exe -- -s -l etc... " instead of "RegisterAddon.exe -- -s -l etc... "  to the System Exec.vi it does not work even if the CallRegisterAddon.exe is in the same directory as RegisterAddon, the cmd /c command changes the working directory.
@Michael
No, I am not using VIPM.
Cristian
(7,134 Views)
Glad to hear it's now working!
This is good to know, thanks for the follow-up.  I'll definitely keep this in mind for the future.
David
(7,134 Views)
