Follow the steps below to install the VI Analyzer Example Style Test Suite, which you can use to ensure the examples for your LabVIEW Add-on follow the Add-on Example Style Guidelines.
- Install and activate the VI Analyzer Toolkit. Note that you can use the example style test suite without the VI Analyzer Toolkit installed, but only the tests in the attached ZIP file will be run.
- Unzip the file below to your [LabVIEW Data] folder. On Windows, this is usually at:
C:\Users\[username]\Documents\LabVIEW Data.
Pay attention that if you have custom tests in your C:\Users\[username]\Documents \LabVIEW Data you will get the VI Analyzer menu option in the Tools menu in LabVIEW, even though you might not have the VI Analyzer Toolkit installed!!! (yes, there is a difference between VI Analyzer and VI Analyzer Toolkit).
One way to know if you have the VI Analyzer Toolkit installed is to see if you have access to Tools>>VI Analyzer>>Create New Test..., if that option is not in your menu, then you don't have the VI Analyzer Toolkit installed.
Another option is to go to NI MAX and under software>>your LabVIEW version see if VI Analyzer Toolkit is listed.
[Edit] Edited to emphasize difference between VI Analyzer and the VI Analyzer Toolkit
When following the suggested steps, note that in LabVIEW 2024 (where I tested), for step 5, the following message appears:
5. In the resulting file dialog, select [LabVIEW Data]\Example Checklist (add-ons).cfg.
