Return to NI Tools Network Software Requirements
| Requirement | Additional Resources |
| Installation | |
| Product is shipped with an installer. | |
| Installer prompts the user if dependent software is not present on a system. | |
| The package includes a EULA which complies with the “Restrictions” and “Application Deployment” sections of the NI Software License Agreement. | |
| Users can uninstall the product. | |
| There is a documented or intuitive update process. | |
| Activation (if applicable) | |
| The add-on is able to be evaluated immediately upon downloading the software. | |
| Users are reminded of the remaining trial time or uses. | |
| Upon the trial expiring, users are prompted to activate the add-on. | |
| The add-on can be activated using appropriate credentials. | |
| Examples and Tutorials | |
| Add-on provides examples and/or tutorials to demonstrate how to use the product in VeriStand. | |
| Examples and tutorials are intuitive and any required steps are documented. | |
| Examples include VI descriptions viewable from NI Example Finder. | |
| Tutorials include explanations to describe what is demonstrated or accomplished by following the tutorial in order to serve as a learning aid for customers. | |
| File Structure | File and Folder Names for Integrating into VeriStand |
| Add-on files are placed in the correct locations. | |
| Files and folders follow a recommended company/product naming convention to ensure namespacing and avoid conflicts with other add-ons. | |
| Model DLLs | |
| Model DLLs import into VeriStand and behave as expected (if applicable). | |
| Documentation | |
| Documentation relating to installation must be accessible before installation. | |
| Add-on contains a help document accessible from the Windows Start menu or within the product. | |
| Documentation describes any installation steps outside of running the installer (if applicable). | |
| Third-party and NI software dependencies are documented (if applicable). | |
| Hardware system requirements are documented (if applicable). | |
| Product directs users to a support channel for technical support. | |
| User Experience | |
| No unexpected crashes or errors reported. | |
| No apparent memory leaks or undocumented spikes in CPU or memory when using add-on and/or examples. | |
| UI has seamless integration within VeriStand. | |
| User interface is intuitive for all utilities, dialogs, and stand-alone applications. | |
| User experience is professional in look, feel, and operation. | |
| User is provided with feedback during long operations (e.g., progress bar, busy cursor, etc.). | |
| The custom device dialog links to a help document (if applicable). | |
| Dialog windows follow the same style as NI dialog windows. | |
| Dialog windows include Help buttons linking to the help document. | |
| Tab order of controls in dialogs are configured logically. | |
| Deployment | |
| Add-on works when deployed for operator-only use (if applicable). | |
| Real-Time Compatibility | |
| User can install RT dependencies through NI MAX (if applicable). | |
| Miscellaneous | |
| Product does not include any malicious software. | |
| Product compiles with NI Tools Network Style Guide. | NI Tools Network Style Guide |
| It is clear to the user when administrator rights are required for successful use of the add-on. | |
| Product and accompanying documentation are localized in English. |
