In order to allow users to activate your add-on automatically over the internet, you must set up the SOLO Server with your product information. You can also set up e-Commerce through the SOLO server.
Note: This information can also be found in the LabVIEW Help.
LabVIEW Help: Enable Automation for the Add-on
Step by Step Tutorial
Tutorial: Setting up the License Server (external link)
« Back to Workflow: Creating Evaluation Software using Licensing & Activation
