DigiMetrix
Any special hardware necessary for Denso RC8 controller
I'm thinking about controlling the robot on a project using the Digimetrix library. Do I need any optional communication board or would I connect to the controller via the same connection as Wincapps does? Thanks for any info!
(5,404 Views)
Hi!
No other hardware or software is needed, use the same connection as WinCAPS.
But please note that both WinCAPS and LabVIEW should not be connected at the same time.
After the library installation, guidelines on your controller setup can be found here:
LabVIEW top menu -> Help -> ImagingLab -> Denso Robotics Library -> Controller Setup Manual.
S
(5,377 Views)
