DigiMetrix
Can't Install Imagelab 3DCreate Addon (VC with Labview for robot simulation)
Hi
  I want to use VC(Visual Components) with labview to control robot, so I want to VC website to download trail 2014 VC software and got trail product key.
In the same time using VIPM download  "Robotics Library for Visual Components - DigiMetrix GmbH", I read a manual to know before i run the software
i had to install "Imagelab 3DCreate Addon"
But when I installed this software, i got this error message
Did anyone meet this message before and how to solve this problem ?
Any advice would be very appreciated.
(12,016 Views)
HI
I could find 3DCreate 2014.ini in my computer
(C:\Program Files\Visual Components\3DCreate 2014)
Moreover, i thought VC was no problem, because I could open it and added a robot in the software.
Thanks for any advice !!
(12,002 Views)
Accepted by topic author ricky10116
Hello ricky10116,
Please download and install the updated version of the library .This version supports VC 3DCreate2014.
The update will be availiable on LabVIEW Tools Network soon.
Should you have any questions about our products or this library please feel free to contact us,
Nikita.
Nikita Prorekhin
CLA
(11,988 Views)
HI
Thanks you Nikita_Prorekhin ,you help me solve this problem asap.
There is more information about how to run this software : It's only compatible with run-time 2009 ,so if you used later version in your PC ,you needed to go NI
IMAX to  check that do you have 2009 version in your computer?  If not, please go here  https://www.ni.com/en/support/downloads/software-products/download.labview-runtime.html#359526   to download 2009
run-time.
  Now VC can connect to labview.
(11,965 Views)
