DigiMetrix
Denso Academic VE026A
Hi to everybody,
I'd like to know if Imaging Lab is compatible with the Denso Academic VE026A, programming it with LabVIEW Robotics.
Thanks in advance.
Kind regards.
Matt
(8,070 Views)
Hi Matt,
the latest version is only compatible with the RC7 controller.
We are currently working on an update for the RC8 controller. RC8 uses the same
software interface as the virtual robot (inside WINCAPS) and the Academic robot
is also using this interface.
So it should be possible to control the Academic robot with the upcoming release.
If you like you can also contact me directly to get the latest news.
Best Regards,
Alexander Kempf
ImagingLab GmbH
(8,067 Views)
