07-29-2013 03:52 AM
Hi,I want to communicate with a yaskawa DX100 controller using the ImagingLab Robotics Library.
Maybe I should set the controller's IP address first.
But I don't know how to set it. Using the PC or Programming pendant or something else ?
Anyone can help me? Thank you .![]()
Solved! Go to Solution.
08-05-2013 09:09 AM
to change the network settings you need to start the controller in maintenance mode.
Probably you need to change the user also to maintenance (or something similar).
If you are still stuck you should either contact Yaskawa service or could send a message to
support@imaginglab.de.
Alexander
08-09-2013 05:48 AM
thank you ~
