DigiMetrix
How to use Robotics Library for Visual Components on 3DAutomate 2014
hello! I use 3DAutomate 2014, and can't install Robotics Library for Visual Components. The install program show " Error:failed to find 3DCreate.ini file. 3DCreate is not installed or your installation si corrupted."
3DAutomate and 3DCreate  are same install file, but they have different install key. 3DAutomate has 3DAutomate.ini file. Do Robotics Library for Visual Components support 3DAutomate 2014?
(7,373 Views)
Hello lzuan,
Yes, the published version of the toolkit works only with Visual Components 3D Create/Automate/Simulate 2013.
If you wish to try it with 3D Create/Automate/Simulate 2014, please contact DigiMetrix at support@digimetrix.com to get the newest build.
Kind regards,
Nikita.
Nikita Prorekhin
CLA
(7,348 Views)
