Digital I/O
1 wire half duplex
Hi, I'm new to this forum and NI/Labview,
Is there a NI cDAQ module that I can purchase for configuring in 1 wire half duplex mode as developed by Maxim. (not RS485 2 wire half duplex)
I could probably achieve this with a tri-state DIO module, but not sure if there is one?
or RS232 module with tri-state capability?
(5,348 Views)
Hi Sparkeyx,
There are a number of NI DAQ devices which support Tri-State DIO. This information can be found in the article below:
http://digital.ni.com/public.nsf/allkb/09B559BE292C75DB8625698500640E0A
Also there is a community example in which the Maxim Integrated 1-wire protocol has been implemented usinf the NI cRIO which you might find useful:
https://decibel.ni.com/content/docs/DOC-24136
Thanks and Regards,
Thanks and Regards,
Supreeth.K
(5,300 Views)
