Digital I/O
16 bit communication with chip
I have a thermometer chip which communicates via 16 bit read/writes (3-wire).  The first 8 bits are a write of the address while the second 8 bits are a read (or write depending on address, but usually will be read after configuration).  The clock can be any speed I choose.  I have a 6251 DAQ, 6541 hi-speed DIO analyzer, 6602 counter, RS-232, and RS-485 modules in a PXI chassis.
I'm not sure how to switch from write to read effectively (and in a timely enough fashion) to write the first 8 bits then read the last 8.  The delay in switching from a write to a read is too long if I use the DAQ to write a waveform then read a waveform on a digital channel.  Seems like the 6541 should be the beast for the job, but I'm not sure how to get it setup.
any ideas?
(3,261 Views)
SirMutt,
see my reply in your other thread:
http://forums.ni.com/ni/board/message?board.id=100&message.id=1596&jump=true#M1596
(3,260 Views)
