Digital I/O
16 bit in /16 bit out IO card
Hey I'm trying to control a stepper motor via ethernet using pulses.  A 16 bit in/16 bit out I/O card would be great.  I was just wondering if anyone had any guidance to where I could find this or something similar.
Thank you,
(3,776 Views)
sobedrinker42,
You will probably need something along this line:
cRIO-9072
with a NI-9512
This will give you ethernet control with a stepper drive.
Dustin D
(3,753 Views)
Dustin,
 thanks for getting back to me. I am currently using a Haydon Kerk chopper motor.  Here is the link:  http://www.hsi-inc.com/LinearMotionProducts/Drives/DCS4020SeriesChopperDrive/tabid/120/Default.aspx
I need to be able to control this chopper drive with a 16 in/16 out I/O.  Would you still recommend the same product as before?
thanks!!
(3,733 Views)
sobedrinker42,
I assume you mean 16 Digital In / 16 Digital out?  If that's the case you should be able to use our PCIe-6535.
Dustin D
(3,709 Views)
