Digital I/O
2 digit decimal to 12 bit binary
Hi
 I want to represent  a 2 digit number into 12 bit binary(boolean array of 12 bit)
ie. 14.4444 to 111111111111
      7.2222 to 100000000000
 Thanks in advance
 with regards
DK
(5,881 Views)
Can you explain how to translate the number into boolean in detail?
(5,867 Views)
I want to Generate a 12 bit binary data on the DAQ card (which is having a 12 digital I/O)  for relation v=0.17404f-11.3191.  where f varies from 70 to 148 with decimal places
(5,865 Views)
Ok, so 14.4444 is your max number.  So what you need to do is (V/14.444)*2^12 = (V/14.444)*4096 = V*283.5779562448, where V is your decimal number.  From there, you may have to do a round to make it a whole number of bits.
(5,859 Views)
