Digital I/O
24v Digital input
I am trying to connect a digital input from a Motor drive. I am using a compaq daq module with a 24v digital input module.
My electronics knowledge is not the strongest. I have attached the picture of the terminals on the drive. Could someone please suggest how i can connect this.
Thank you
(2,960 Views)
Um, Be careful.  That image that you attached shows 48V while you explicitly stated you have a 24V DAQ device.  If you drop 48V across a 24V DAQ device it is possible to destroy the DAQ device.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(2,916 Views)
