Digital I/O
5V stability
Does anyone know if the 5V output on USB-6210 has some kind of voltage regulator to keep the voltage stable?
My application is I want to use this 5V output for supply to 3 linear transducers, therefore getting a signal back of 0-5V.
If the voltage supply can fluctate then it will invalidate calibration factors.
(3,820 Views)
EDITED: This reply had incorrect information, I apologize for the inconvenience.  Please see the next reply.
Kind Regards
Michael
NIUK Application Engineer
(3,786 Views)
Hi Cooper1,
The level of the +5V output can fluctuate with load. You should however be able to overcome this problem by monitoring the level with a spare AI line in order to ensure accurate calibration of your linear transducers.
I hope this helps, but let me know if you have any more questions.
Christian Hartshorne
NIUK
(3,757 Views)
