Digital I/O
6251 digital trigger issue
I am trying to read an analog waveform with a PCI-6251 and digital trigger. Using the SCB-68 E terminal box.
The analog input works fine without triggering.
When I connect the digital trigger from my function generator sync output to PFI 0 (pin 11) and DGND (pin 12) the square wave is pulled to zero volts.
Same occurs for any other PFI x combinations.
The DIO port is configured as input per NI MAX.
As a result my VI times out and generates an error because it is waiting for the digital trigger.
What am I missing?
Look forward to your suggestions.
Csaba
(5,606 Views)
Hi cszeles,
Have you tried running any of our examples?
Go to Help» Find Examples...» Hardware Input and Output» DAQmx» Analog Input» Voltage - Continuous Input.vi
Joel I.
(5,578 Views)
Hi Joel,
Thank you for your suggestion.
I had a faulty cable that that prevented the supply of the digital trigger signal.
The VIs and the 6251 work like clockwork.
Csaba
(5,549 Views)
Glad to hear it!
Joel I.
(5,543 Views)
