Digital I/O
6361 counter output not working
I'm trying to generate a 0-5V PWM signal from the PXI6361 using the Counter Output pins but it doesn't seem to be generating anything. I've measured the otuput using both a multimeter and an o-scope and both are reading 0 volts - even when I turn the output frequency to extremely low.
Right now I have my wires connected to the pins PFI12 and ground. I have also tested PFIs 13 and 14 and none of them work either. However the digital and analog output ports on the PXI are working just fine. NI-MAX has also verified that I am communicating with the device successfully.
Any insight on why this isn't working would be really helpful. Do I need to wire the +5V on the 6361 as well?
 List of devices I am using:
1. NI PXIe-1072 chassis
2. NI-PXIe-6361
Thank you!
- A very sad intern who swears she's not insane
(5,676 Views)
What code are you using to generate the PWM signal?
Are you just using test panels in MAX, a LabVIEW example, or something else?
-Jim B
Applications Engineer, National Instruments
CLD, CTD
(5,625 Views)
I am running this through NI MAX for now.
Thanks for the reply.
(5,607 Views)
No, you don't need to have the 5V connected, but I can't think of why the PFI line would work as a digital I/O, but not as a counter output.
You could try opening a counter example in LabVIEW and see if that gives any better results.  For instance, "Counter - Continuous Output.vi" is probably a good example for this application.
-Jim B
CLD, CTD
(5,589 Views)
