Digital I/O
6501 Active Driver control in LabVIEW
I'm trying to configure my USB-6501 digital outputs as push-pull in labVIEW. The default is set for open-collector.
I can't seem to find any setting for labview DAQ assitant or if I make my own DAQ channel task.
Using LV 9.0f3 (32-bit).
Thanks!
Vinny
(3,261 Views)
Use a channel property node. You should be able to select Digital Output>Output Drive Type.
Message Edited by Dennis Knutson on 05-01-2010 01:36 PM
(3,247 Views)
