Digital I/O
6501 SelfTest programmatically through C#
is it possible to initiate and check a 6501 Selftest by .Net / c# ? ( After Notebook restart, NI 6501 often looses connection to notebook, maybe because its behind a usb hub - any idea ? )
regards, Rolf Harbauer
(3,546 Views)
Hello Mr. Halbauer,
unfortunately there is no function for a selftest. But you may use another fuction to test the communication. For example you can query the serial number.
It returns an error if no device is availabe.
If you include the DAQmx library you can use this function in C#.
Regards
DianaS
(3,527 Views)
