Digital I/O
6501 resistance to ground
Hi there,
I am trying to drive two pins to be either grounded or floating; they will always be opposite of one another, however, when I switch either of the pins to low, there is still an ~80 ohm resistance between the IO pin and any of the ground pins and giving undesired results. I have been switching the pins from high and low states by toggling them within the "Test Panels" part of NIMax for the device. Is this something that can be lowered through drive configurations (push-pull/open-drain), or possibly another way? Or would this be a limitation of the device itself?
(499 Views)
Please share what you're driving to understand better why and how to achieve it
Santhosh
Soliton Technologies
(477 Views)
