Digital I/O
6534 16 bit I/O PG 10MHz
How do I configure the NI-6534 to send a pattern generation of a buffer of 16 bit words and receive the same number of words (as if talking to a FIFO or looping the output back to the input) at 10 MHz on the internal clock? In other words, for each word I send I need to receive a word. I am currently using single buffering, ports C & D for output, A & B for input, no external gating, latched input, unlatched output, timebase of -3, and interval 2. I call DIG_Block_In and then DIG_Block_Out with the data. All I get back is zeroes. I think this is a configuration problem. I am using LabWindows/cvi. Please help.
(3,124 Views)
Greg,
I believe I responded to an e-mail from you. Can you send me the code you are running? I'd like to see what you are doing. When you say all you get back is zeros, does that mean that your input only reads zeros? What does your output do? Have you verified any output (on a scope perhaps)?
Salvador Santolucito
Applications Engineering
(3,124 Views)
