Digital I/O
6534 PFI4-7 and NIDAQmx
I am in the process of porting some software writting in Traditional DAQ to DAQmx.  We use the PFI4-7 pins on the NI6534 for general purpose IO.  I did not have any issues programming/using these lines on the same PC under Traditional DAQ, but have been unable to get them to work under DAQmx.  I have even tried to use the DAQmx softpanel for the device, but toggling the state of lines 0-4 on port 5 do not result in any state change on the physical pins.
Here is the code that I'm currently trying to use with DAQmx.  The variable szChannel results in "Dev1\port5\line0:0".  I have also tried "Dev1\port5\line0" without luck.  Any help is appreciated.  I'm currently using DAQmx 8.6.0f12.
int CVIFUNC DaqMxSetDiscrete (char* szDevice, int discrete, int state) {
 char  szChannel[256];
 uInt8 data[1] = {0};
 int   error = 0;
 TaskHandle taskHandle = 0;
 data[0] = (uInt8)state;
 GetDaqMxChannel(szChannel, szDevice, discrete);
 DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
 DAQmxErrChk (DAQmxCreateDOChan(taskHandle, szChannel, "", DAQmx_Val_ChanPerLine));
 DAQmxErrChk (DAQmxStartTask(taskHandle));
 DAQmxErrChk (DAQmxWriteDigitalLines(taskHandle,1,1,10.0,DAQmx_Val_GroupByChannel,data,NULL,NULL));
Error:
 if( taskHandle !=0)
  error = DAQmxStopTask(taskHandle);
  DAQmxClearTask(taskHandle);
 return error;
(3,768 Views)
I upgraded to DAQmx 8.9 and am now able to control PFI4-7 without issue.
(3,758 Views)
After upgrading to 8.9, I am able to control PFI4-7 using the test panel in MAX, but cannot get the state to change for these lines from within my program.  I've tried creating a DAQmx task from within CVI.  When designing the task, I can change the state from the softpanel, but once I use the generated code within my application, no state change.  The code it generated for one of the PFIs is:
int32 CreateDAQTaskInProject1(TaskHandle *taskOut1)
 int32 DAQmxError = DAQmxSuccess;
    TaskHandle taskOut;
 DAQmxErrChk(DAQmxCreateTask("DAQTaskInProject1", &taskOut));
 DAQmxErrChk(DAQmxCreateDOChan(taskOut, "Dev1/port5/line2",
  "DigitalOut", DAQmx_Val_ChanPerLine));
    *taskOut1 = taskOut;
Error:
 return DAQmxError;
Then I call the function as follows:
 CreateDAQTaskInProject1(&taskHandle);
 DAQmxErrChk (DAQmxWriteDigitalScalarU32 (taskHandle, 1, 10.0, 1, 0));
Michael
(3,754 Views)
Ok... figured out that for the PFI lines, I must write the data as if I'm doing a port write.  I'm not sure why this differs from the other ports where I can address lines individually.  In order to set PFI6, I have to write the value 0x04.
(3,753 Views)
