Digital I/O
6534 in Pattern Generation Input and Output
Hello All
I have a PCI 6534 High Speed Digital I/O card that I am trying to use to generate a pattern output from port A and acquire some data from port C. I have connected Port C, bit 0 to high and all the others low and I have also connected the two REQ pins together. This is to allow for the REQ pin from the pattern generation output to drive the input as an external clock. I have set the timebase as 1uS and the request interval as 10, to give a REQ pulse every 10uS. The idea being that the pattern generation output will generate a REQ pulse every 10uS and this would cause an input read to occur. My code can be found in the attached word file.
Now initially I placed the DIG_Block_In command before the DIG_Block_Out and set the two counts to 100. For a single run of the application this filled my input buffer array with 50 elements of 257.... which I think is what I would expect as for a count of 100 it takes 2 to fill both the upper and lower 8 bits of the input array. OK....
Now if I change the In Count to 200 and leave the Out Count at 100 I only fill 48 elements. I have no idea why this would happen. In my finall application I hope to increase the count to nearer 2000 and this loss of elements becomes significant.
If I swap the DIG_Block_Out command to go before the DIG_Block_In then with both counts set to 100 I get no data acquired at all. If I increase both counts to say 2000, I actually acquire 944 elements, 56 less than I would expect? Why is this....?? Is it because the DIG_Block_Out command has already started the process before the DIG_Block_In command is initiated?
Does anybody know what is going on here? I have had the same problem with a PCMCIA 6533 card (worse) and thought it would be solved with the PCI 6534. Does anybody know how I can ensure the correct numbers of data are acquired every time I run this operation? I need to be sure that all the desired data is being acquired as my final application is very dependent on this.
Any help would be gratefully appreciated.
Jamie
(3,199 Views)
Hi Jamie,
Whenever you are communicating from one group to the other on the 653x boards, you should have the input clocked on an external signal and you should have the output start AFTER the input process has started.
As for why your input buffer is half your output buffer, it could be that the intermediate PC memory buffer is in terms of bytes and your application buffer was casting this data to a 2 byte word.
I linked on one of your other posts 2 example programs. Adapting those might suit your needs best. Have a good day.
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HFORCEKWTID=75069:5&HOID=5065000000080000008BA10000&HExpertOnly=&UCATEGORY_0=_31_%24_12_&UCATEGORY_S=0
Ron
(3,199 Views)
