Digital I/O
6537 problem from MAX
Hello everybody,
I am using DAQmx 8.5 and I simulated PCI 6537 card in MAX. I created a task with one digital input line say Dev1/port0/line0. I configured the task for N sample acquisition. Sample rate is 1K and # of samples to read is 100. When I ran the task, it didn't stop at all!!! I had to abort the task. But the data was acquired and the data got plotted in the graph. Obviously, the same thing happens from LabVIEW also.
Do anybody know why this happens???
Saranya
Note : All the other tasks (with other devices) are running properly.
(3,340 Views)
Hi Saranya -
I'm not aware of any problems with this simulation.  Could you post the code you used?  I'll try it out on my system.
David Staab, CLA
Staff Systems Engineer
(3,327 Views)
