Digital I/O
6602 / hardware / filtering
Hi All
System Specs:
I am using a 6602 pci card (R6868 cable to TBX68).
I have LV8.2 code to output (4) 1KHz counter outputs (3) of which are delayed by 1us.
I use Same Trigger for all (4) continuous counters from io port0 line0 to PFI38.
Issues:
The 5V TTL high level of the 1st counter exhibits a 1V dip during the rise time of the other 3 delayed counters.
Support requested:
1. How to; filter the voltage dipping affect ?
2. How to; decrease the rise time [currently100ns].
Ryan
(3,762 Views)
1. What is the device and it's input characteristics that the counter signals are connected to? Wondering if it is excessively loading down the counter outputs? May need a buffer or line driver chip between the 6602 and your device.
2. Risetimes can be slowed down with resistor/capacitor filtering.
(3,759 Views)
First I measured unconnected cnt0 output; and then connected and measured LM 6125 buffer out; both methods gave exact same dip and rise time mesasurements.
(3,755 Views)
To recap
I am not driving the device yet
I am not using any resistors or caps at this point
With and without buffering, I measure dip of 1v and rise time 100ns.
I tried two different 6602 computer systems and both exhibit these same characteristics.
How might I reconfigure and/or filter 6602 output to improve "counter cross talk" dip; and risetime?
Ryan
(3,740 Views)
Hi ztruth:
If the counter output droops without the 6125 connected, then I am guessing maybe the other 3 counters are dragging it down (poor board design or excessive loading- I do not know) but even with 1 volt droop it still conforms to TTL logic level high specifications. What are the other 3 counters connected to? Have you repeated the test with them disconnected also?
I misread your request on risetime- you can't decrease from within the board, maybe a high speed schmitt trigger would help prior to the 6125's input.
According to what I saw on the Web, the LM6125 has been out of production for nearly 12 years. It is a nice chip though. What are you driving with it?
-AK2DM
(3,743 Views)
