Digital I/O
66312A connecting labview
I have installed the driver for the 66312A DMM and I want to control it with Labview.
I hadn't had much progress because it's different from measuring, and I'm good with that.
Any tips?
(4,175 Views)
First of all, where did you get this driver from and what kind of driver is it? Is it a LabVIEW Instrument Driver or just a set dlls you can call? If it is a LabVIEW driver it normaly installs example programs along with it to try.
Kind Regards,
RikP - National Instruments Applications Engineering.
Rik Prins, CLA, CLED
Software Development Engineer
(4,164 Views)
Yes it's a labview driver indeed.
It has a lot of examples, but there are none which i can use or learn from.
I'll go check it out!
(4,159 Views)
Hey melk,
Where did you get the LV drivers.  I couldn't find them on NI's website or agilent's?
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,079 Views)
Well, I couldn't find the LV driver but it works using VISA---- SWEET!!!  Score one for VISA!
jigg
CTA, CLA
testeract.com
(4,057 Views)
