Digital I/O
7820R default clip
I am trying to setup a labView FPGA project for the 7820R. I am able to create the FPGA project in labview 2018 but I don't have a component-Level IP file to be able to use the128 pins of DIO so I can build my labview FPGA bitfile. Is there another driver that I need to install for the default component-Level IP or is it installed on the PC but I am just not aware of where it is located.
(2,809 Views)
All drivers required are listed on page 3 of getting started document below.
http://www.ni.com/pdf/manuals/376820a.pdf
There should be examples at NI Example Finder in the Hardware Input and Output\R Series\Device Specific\PXIe DIO Devices folder.
(2,015 Views)
