Digital I/O
9402 maximum Output Current for driving Broadcom HFBR-1521 LWL Transmitter
I would like to connect a Broadcom HFBR-1521 LWL Transmitter to the NI 9402 DIO in a cRIO-9063 cabinet.
What is the maximum Output Current of the 9402?
If it is below 20mA I'm going to use an additional driver.
Best Regards,
Chris
(2,848 Views)
Accepted by topic author Logtrop
Most DIO only handle more around 4mA.  From what I am seeing in the spec, I would say the 9402 is rated for 2mA.  So you will definitely need a buffer circuit.
(2,831 Views)
