01-17-2008 04:48 AM
01-18-2008 10:51 AM
01-19-2008 09:00 AM
01-21-2008 01:32 PM
Thanks for providing the additional information.
When I asked what pin you are connecting to, I meant the actual pin number on the terminal block. I want to check and make sure that the physical pin you are connecting to actually corresponds to the ACK signal output. Sorry I wasn't clearer on that one.
I do suspect that there could potentially be something wrong with the hardware, especially if it's not even working with the LabWindows shipping example. Which example did you run? Also, how long have you had this device? If you have used it before, did you notice this problem previously? Can you think of anything that could have happened to damage this device?
One other thing to check: have you verified that your clock signal from your peripheral device is coming in as you expect it is? To do this, you could try running the example program you used previously, this time allowing the DIO-32-HS to generate its own PCLK, rather than importing the PCLK signal from the peripheral device, and see if this results in the same problem with the ACK signal. Give this a try and let me know what you find out.
