Digital I/O
AUX I/O port on NI 5732
I have an NI-5732 adaptor on PXIe-7975r,now i want to read data from DIO ports on IO module.I consulted NI 5731/5732/5733/5734R User Guide and Specifications and it says that :
1.Use any HDMI cable with the provided ferrite bead to connect to the digital I/O and PFI signals on the AUX I/O connector.
2.The AUX I/O connector accepts a standard, third-party HDMI cable.
Im confused because several problem:
1.How do i read data through AUX I/O connector ?
2.What kind of adaptor or other divices do I need to connect to NI 5732 through the cable and how could I get one ?
3.Any extra module,driver or software do I need to use?I got an NI 7975r FPGA and FPGA,FlexRIO module.
If there is any unclear expression, I apologize for that.
(1,003 Views)
more information:
routed to the Nano-Pitch I/O connector. These transceivers
can be used for high-bandwidth communication with other devices over high-speed serial protocols such
as Xilinx Aurora, 10 Gigabit Ethernet UDP, 40 Gigabit Ethernet UDP, or Serial Front Panel Data Port
(SFPDP).
(994 Views)
You will need LabVIEW, LabVIEW FPGA, and the FlexRIO driver.  If you open the shipping example for the 5732 you should be able to add these I/Os to the project.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(965 Views)
Thank you for your reply!
Yes I can read the DIO port data from a host,but if I want to read some external data though a DIO port on AUX I/O socket,how could find a proper wire and a source?
(939 Views)
